An incoming UDP echo packet from the mentioned socket was received.
This is for debug purposes and should only be enabled on request of Extreme Networks technical support.
Debug-Verbose
UDP packet from %sip%:%spo% on socket %sock%-%vrid% type %type% code %code%
| Name | Type |
| sip | srcIPN |
| spo | srcL4port |
| sock | sInt |
| vrid | uInt |
| type | uInt |
| code | uInt |
